Hi there.
When I use "Scan video stream for errors..." with VirtualDub on my divx files, the end result is says something like, "0 frame bad, 0 frames good but undecodable." What does that mean?
Bravoxena
That means no problems and you can use your file as is!
8)
"Art is making something out of nothing and selling it." - Frank Zappa -
LOL! Who ever thought that 0 frames good would mean everything is well.
Thank you.
Bravoxena -
The report goes like this: X frames bad, Y frames good but endecodable, (X+Y) frames masked. When you save avi, all the masked frames (bad and undecodable) are not saved as part of the stream.
Yes, 0 frames bad and 0 frames good (and undecodable) is what we all hope for when we scan!"Art is making something out of nothing and selling it." - Frank Zappa -
Zippy...
when you 'save avi', will virtualdub replace the bad and undecodeable with something else (like a duplicated frame close to the bad frame), or will they just be left out? If you had many bad frames, just removing them would cause desynchronisation, right?I wanna be bigger, stronger, drive a faster car... -
When saving the file the bad frames are lost, both video and audio, and that segment of the movie is gone. It should not cause any sync problems, on the contrary it helps prevent sync problems when converting the files with any mpeg encoder.
8)
"Video: Stream attributes could not be determined" in Sony Vegas
By bloodshed in forum Newbie / General discussionsReplies: 41Last Post: 6th Nov 2012, 06:12 -
I don't understand these errors saying "wrong version".
By saltyjd1 in forum Authoring (Blu-ray)Replies: 3Last Post: 28th Mar 2011, 14:52 -
DVD with menus, replacing "bad" video with "good" video
By chipsndukes in forum Authoring (DVD)Replies: 34Last Post: 4th Dec 2008, 17:45 -
Please explain "Progressive Scan DVD menus"
By schematic2 in forum Authoring (DVD)Replies: 1Last Post: 2nd Oct 2008, 19:25 -
I'm totally stuck "unrecognised message" and other errors
By marinebc11 in forum MacReplies: 22Last Post: 26th Aug 2007, 17:32
