Hello,
I have a video of 3000 frames. I have configured the logoaway filter in virtualdub to blur out the unwanted non moving logo in the corner of the screen. The logo is only present durning frames 500 - 600. How do I tell the filter to only be active during those 100 frames?
Thank you.
Kreg
Looks like the only way you could do that is to mark start and end using the keyframes, and just save that section with the logoaway on. (Keep compresion same as original)
Then delete that section, remove logoaway filter and save the rest as a stream, combine the two later.
To combine, both AVI's must be same type, or make 2 mpegs out of your new AVI's with TMPGEnc
yep,
I just thought there might be an easier way. I did that exact same thing last night, and it works fine. I thought maybe there would be a point where the joining of audio would glitch or pop, but it doesnt as long as you keep the frames in the right spot.
Thanks,
Kreg
Logoaway
By syncro in forum EditingReplies: 5Last Post: 24th Dec 2015, 01:57 -
Avisynth script to blur, similar to Logoaway XY (mode)
By jairovital in forum EditingReplies: 18Last Post: 6th Aug 2011, 08:24 -
Logoaway and ffdShow
By syncro in forum DVB / IPTVReplies: 3Last Post: 1st Feb 2009, 14:23 -
Logoaway filter for AviSynth?
By DRP in forum Video ConversionReplies: 2Last Post: 8th Aug 2008, 05:30 -
Using Logoaway in two-pass mode
By AlanL in forum EditingReplies: 1Last Post: 21st Jun 2007, 07:54
