  1. Hey all. I am trying to encode a .asf file to mpeg and I can't get tmpgenc to open the file. I have read everything I can find on here and it says that that program should open the files. I can't get it to. Is there another set of codecs that I need to get tmpgenc to open that file? Or some other program that I would need to install to do this?
    Thank you all
    Modartist
    Some are born to rule the world. to live their fantasies.
    While most of us just dream,
    of what we would like to be.
  2. Member Conquest10's Avatar
    Chicago, IL
    you need to convert it to avi first.
    His name was MackemX
  3. your asf might also be corrupt.
    Bravoxena
  4. Thank you , I have tried that in vdub but it wouldn't open the file either. I did however find a program on here aafter getting yoru help that would do that . I appreciate you help
    Thanx
    Modartist
  5. Try TMPGenc - you'll need to set the priority of the directshow encoder to high
    Panasonic DMR-ES45VS, keep those discs a burnin'
  6. I believe Virtual Dub no longer supports .asf, but version 1.3c is the latest version that does support it.
    Thx in Advance!!
  7. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Try ASFTools. Can convert to AVI and extract audio to WAV among other things. Suffers heavily from sound sync problems, but nothing that can't be fixed with a little determination.
    /Mats
