I am trying to help a friend who wishes to convert satellite shows to svcd.
He is using the s-video out of the satellite receiver, to a Sony 8mm DV camcorder, to a 1394 firewire board.
Is it best to capture to tape, or stream directly, or does it matter?
Which program should be used to capture, and to what format?
We were trying to capture to mpeg2 with PowerVCRII but it just gave DV control errors??
We will then convert to SVCD with tmpgenc
Mark
either a direct stream or record to tape and playback, it makes no difference to the quality, but obviously capping to tape and playing back is way more convenient.
there are loads of DV capture apps. DVIO is no frills and free, DVapp gives you a nice preview, and Scenalyzer is $30 or so, but those who have bought it are very happy with what it can do. your captured DV will be in an .AVI file, and you can open this in TMPGenc no problems. -
I am not sure if PowerVCRII can capture as SVCD or not, but there are other programs that let you capture directly as SVCD (ULead Video Studio 7, WinDVD Recorder, etc.) ULead VS 7 also has a very nice editor that you can use to cut the MPG file.
Windows 7 (x64) and Set Tob Box Firewire (1394) capture?
By techiejustin in forum Newbie / General discussionsReplies: 4Last Post: 2nd Jun 2011, 21:57 -
DV to PC -- Firewire Problems; 1394 vs. USB; Capture Software
By GrayStrickland in forum Capturing and VCRReplies: 1Last Post: 27th Apr 2010, 12:27 -
Can't capture from HDV tape!
By frlane in forum MediaReplies: 8Last Post: 2nd Jul 2009, 16:43 -
VHS tape capture "flickering" - Intensity Pro Capture Card
By mofaster in forum Capturing and VCRReplies: 2Last Post: 31st May 2009, 13:56 -
iDV (1394) Capture Problem
By couchdirector in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 21st Jul 2008, 14:59
