anybody out there know of any software thast can make a vcd or svc with multiple angles, like on some dvds?
Results 1 to 9 of 9
Not Possible.
AT ALL.
NO WAY.
No such thing.
That's like asking if I could encode some smells into a VCD like on my AromaDiscs.
Sorry,
Scott -
i only asked a sensible question, was it really necessary to be so sarcastic? i thought the whole idea of having a forum such as this, was so people could ask questions & get sensible replies. it's also not an unlikely possibility to make such a cd, i'm sure i've seen a message from someone else, about it a long time ago, but i didn't check on replies.
Don't sweat it. There was supposed to be a
on there. -
Technically, you can't make a multi-angle SVCD, but you can work around it and preserve all the angles.
First of all, rip DVD with DVD Descryter that can process multi-angles. It keeps all the angles sequentially. When authoring your SVCD, make each angle a chapter, you can switch between angles with FF and FB button. Not as convenient as true DVD multi-angle, but it is serviceable. -
Poplar,
Good try!
If you make Angle1=Chapter1 and Angle2=Chapter2, this is what would happen:
Watch A1(Ch1) for a while, use FF(Next) to switch to A2(Ch2)--BUT A2(Ch2) will start at the beginning of the chapter.
Want to go back to A1(Ch1)?
If you use FB(Previous), you'll go back to the beginning of A1(Ch1).
I don't know, maybe using "Multi-Default" might work, or lots of "SEGMENT" hopping with PBC. I don't think it's worth the effort.
@EnNiS:
I'd tell you more if you asked nicer. Suffice to say, its a disc that you put in a player and it smells good. Stupid but fun. Do a google search.
Scott -
hmm, sounds like it's going to be a lot of hassle to me, on my slow pc it'd take ages to do. i was hoping there would be a simple piece of software that'd do all the tricky work for me, but i guess not.
thanks for the suggerstions anyway.
Ripping with angles
By Dozza in forum DVD RippingReplies: 4Last Post: 18th Apr 2019, 14:54 -
adjust angles
By ecos in forum EditingReplies: 2Last Post: 31st Jan 2012, 17:00 -
blu-ray multiple angles in a stream .... question
By zero7404 in forum Blu-ray RippingReplies: 0Last Post: 19th Sep 2011, 18:51 -
How to rip a dvd when with multiple angles
By denadel in forum DVD RippingReplies: 1Last Post: 2nd Jan 2010, 16:34 -
Playback of DVD authored with multiple angles has stuttering sound
By kipling100 in forum Authoring (DVD)Replies: 2Last Post: 14th Nov 2009, 21:54
