I have a Pioneer 104. I want to know which blank media is best to use. Is there a "short list" based on media speed and compatibility? The media section lists every disk known to man... I just want to know the best 2x and 4x to use for compatibilitywhile also considering the price... Thanks
Results 1 to 14 of 14
Almost impossible to answer as everyone had different criteria. The DVD Players that you will be playing on also makes a difference as to which media is better.
I have a Cendyne/Pioneer DVR-104 and DVR-105 and 2 Sony DVD Players and an Old RCA DVDPlayer and I like TDK 2x, others say they are tooo pricey.Cendyne/Pioneer 105 & 104 with a Dazzle* Hollywood DV-Bridge. -
I have to agree with gcutler.
i have not had one single problem with the TDK 2x media.
I burn with a Sony DRX-500UL and it plays back flawlessy on my Sony PS2 and DVP-C660.
You can find them for $40 for 15...Use what works for you... -
As well my best price for the spindle of 15 for $40 at Staples.comOriginally Posted by tjtoed
http://www.staples.com/Catalog/Browse/Sku.asp?PageType=1&Sku=501533
Sadly I can't seem to find the 40 (or is it 50) spiindle for a more cost effective price than the 15 @ $40.Cendyne/Pioneer 105 & 104 with a Dazzle* Hollywood DV-Bridge. -
Does Taiyo Yuden made DVD-R's?
All the DVD-R's (and +'s. etc) appear to be made in Taiwan. Can I get some that are from Japan?
Whatever you do do not buy Princo's. Search for many threads on that topic.
I have had no issues with Ritek's. They seem to be the best inexpensive media while still maintining quality.
Yes, Taiyo Yuden makes discs, but I believe they're over 2.00 each.
See meritline.com or to the left under DVD Media~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
Originally Posted by cacloss
Pioneer 104 doesnt burn at 4x
I have mixed feelings about princo.....the 1x certifid Princos are crap but I havent had any problems with the 2x certified Princos. and i have burned ALOT of stuff on 2x and 1x Princos as well as Ritek silvers and golds
other than that u can by 1x riteks and with a firmware hack u can burn these stable at 2x......WWW.QTCCDR has riteks for as cheap as $1.05
they are located in santa ana california., I dont know about their shipping rates since I work down the street from them I'm able to walk there and get what ever I wantcheck out http://www.geocities.com/eatin_sammiches/sprucecreations.html to download additonal buttons and backgrounds for SPRUCE-UP menu creation -
I have to give my nod to the Ritek G03's. No, they are not the best media that you can buy, but for just over a dollar a disk and the ability to burn at 2x with the hack, I think they're great. I have yet to burn one that would not play on my standalone perfectly. However, you do have to be careful who you buy from. I think that's just as important as what you buy. I got mine at Rima and have been satisfied, but I've heard to stay away from Allmediaoutlet.
I was dumb enough to buy 50 PRINCO DVD-RW's for my first purchase and had a success rate of less than 50:50. I didn't know about this Forum at that time. DON'T BUY PRINCO
This is so much fun! -
i get the accu dvd-r myself. never made a coaster yet and all have played fine. done about 70 so far.
Any local retail places that carry the Taiyo Yuden DVD-R's?Originally Posted by spidey
I only need to to make a few DVD-R's, so the extra $1/disc doesn't matter to me. I'm not buying a DVD recorder anytime soon, just using the one at my friends to make a couple of discs. And what brand name are the TY's marketed under? -
If you want very high quality and do not mind paying for it try Apple DVD-Rs, they are 2x and you can get 5 for about 15 dollars. Also Verbatims are awsome for most.
However, if your trying to ride that price/performance line then Ritek G03 all the way. -
Hmmmm..... I almost use nothing but princos cause they are cheap. about 1us. No problems except when doing disc to disc. Don't know the reason? Don't have time to test. But I do perfer Riteks. They have a darker dye. PS2 likes those disc lots. But those are 1.40us. I do burn them 2xs. I have to finish using the Princos. I bought alot cause the price was going to go up alot. Haven't tried other disc. Like they say "if it works don't try to fix it."
Joe328 -
Have you tried the Princo DVD-RW. I bought 50 for my first purchase from Meritline and they have worked horribly. On several disks half way through a burn on Prassi, it will kick out the dvd and give some error. Maybe I got a bad batch.
haali media - use custom media type for h.264
By adom in forum Video ConversionReplies: 0Last Post: 15th Mar 2011, 06:07 -
AccountKiller
By rcvalle in forum MediaReplies: 3Last Post: 13th Dec 2010, 22:05 -
How To Convert DVD Media Made From VHS Media For Sharing Online
By BlazingSpeed in forum Video Streaming DownloadingReplies: 0Last Post: 11th Dec 2010, 14:20 -
No Sound Coming From Media Player or Online Media Players
By Teac23 in forum AudioReplies: 4Last Post: 11th Jul 2010, 07:52 -
DMR-EZ27 records on rewriteable media, but gives U61 error on other media!
By dr-rjp in forum DVD & Blu-ray RecordersReplies: 2Last Post: 11th Jun 2008, 18:58
