I usually download divx movies off the net, and burn them on a CD. Now i downloaded a movie that was over 700mb and it wont fit on one cd. I know i can cut them in half and burn them to two cds. My question is simply, Is there a way to get better video/audio quality from a divx, and saving it again as divx? Then i would simply cut it in half and put them in two cds. Thing is i dont really want to waste two cd, while if, there is a way to get better quality on the film! Now also, then i would like need some kind of calc, so i wouldnt go over the need mb's.
Thx for ya help, peace,
Kevin
You can buy up to 870MB CDR's here http://www.allmediaoutlet.com/9099minutes.html
Ok i know i can buy over 700mb media cds...but really that wasnt my question...i just want to know if there is a way to make the divx file better quality...audio and video....!
Thx -
I don't know however I do have a keen interest in divx in general since we know soon there will be DVD players that will play divx files.
no you can't make quality of anything better. you can't just invent better quality, there's no filter that will add detail to the image and dynamic range to the sound, it just won't happen.
You can't get better quality out of a movie . there is no way but you can put the movie on one disk in Tmpgenc.Here is the page to help you with that
https://www.videohelp.com/forum/userguides/84759.phpModartist
Some are born to rule the world. to live their fantasies.
While most of us just dream,
of what we would like to be.
Best quality DVD output software for maintaining photo quality
By P_Erickson in forum Newbie / General discussionsReplies: 20Last Post: 21st Apr 2012, 22:30 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 19:23 -
3 AVIs to DVD low quality or medium quality to drive then DVDshrink?
By johnharlin in forum Video ConversionReplies: 5Last Post: 4th Apr 2009, 02:18 -
lower low quality online tv how to high quality :( :x
By gorry563 in forum Video Streaming DownloadingReplies: 1Last Post: 22nd Feb 2009, 06:56 -
&fmt=18 does not give the same quality as playing by "high quality
By arminio in forum Video Streaming DownloadingReplies: 2Last Post: 9th Feb 2009, 18:33
