I want to extract audio from an avi (eg as a wav) and then reinsert it (use TMPG - vid source / audio source). However, when I do this with the programs I have tried so far, the sound on the product is out of sync.
Please Help.
PS Whenever I use NanDub (VirtualDub opens file with "improper audio stream" anyway) it crases when I try and convert.
Results 1 to 9 of 9
Thx in Advance!!
what type of audio compression is in the original avi file?
mp3 or ac3? -
~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
I use 'Dub to extract the WAV fine - but get an error when HeadAch3 tries to open it!!!
Thx in Advance!! -
Hi im finding the same error , about interfaces and chunk data file when i try to follow the above guide , with headachAC3 023a ,when i open my files
Is the error about a missing .dll ? cause I had that, you will need to download this - http://mitglied.lycos.de/darkav/download/azid_dll-1.8.rar
, extract the files to the same folder as headach3.
I am having similar problems to you, im still not getting audio in synch , even after following the guides on here. its a pain in the neck. Let me know if you come up with an alternative solution to the ones on here. -
whoops , the link doesent work for some reason, u need to go here - http://mitglied.lycos.de/darkav/ click on downloads, and then click "azid.dll" to download the file, if you havent already.
right , i got headac3 updated , but still it tell me my drive has no space , but it has 19gb according to my drive space, when i press start to run headac3
Extracting Just The Musical Audio
By niteghost in forum Authoring (VCD/SVCD)Replies: 9Last Post: 6th Jan 2011, 05:09 -
Extracting audio from .ts
By leopardx in forum Video ConversionReplies: 2Last Post: 23rd Apr 2009, 16:22 -
Extracting audio with VirtualDub
By RedPenguin in forum Newbie / General discussionsReplies: 12Last Post: 16th Dec 2007, 19:03 -
Extracting audio from AVI's
By KoolDrew in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 20:24 -
Extracting audio from avi - only does first 13mins
By DBIV in forum MacReplies: 5Last Post: 21st Jul 2007, 20:27
