I have some captured material I need to be 100% compatible with the vcd standard, which I know is 1150 video, 224 audio, bu I was wondering if 1246 video 128 audio is also VCD compatible as it also adds up to a total bitrate of 1374. Would it just be safer to encode to 1150/224 or is it the same thing?
kustomkla80;
The vcd standard requires that the videobitrate is 1150 and the audio
is 224. If you encode a vcd with any other bitrates for video and audio it's
no longer a vcd, it's a xvcd.
The biggest problem if you want a 100% compatible vcd is that it's not
so many mpeg encoders that can produce a 100% compatible mpeg file.
Tmpgenc encoded mpeg files using the vcd templates or setting it manualy
doesn't produce 100% compatible files. The only encoder i now so far that
can do this is the lsx 3.5 encoder.
Some players requires that the vcd is 100% compliant, otherwise the can
produce some artifacts while playing. The most common artifact due to the
mpeg not being 100% compliant is green colored squares in the picture.
the only player i now so far to have this problem with mpeg files that are not
100% compliant is philips CD-i player model 210.
The number of players affected by this is very small, so it's not a big
problem at all. If you against all odds should enconter this problem,
you now whats causing it.
Vcd4ever. -
thanks. is lsx 3.5 better or worse quality than tmpgenc? If it isn't, for mpeg1, is there anything better than tmpgenc?
kustomkla80;
Tmpgenc is imo the best mpeg1 and mpeg2 encoder. I have tried many mpeg encoders but tmpgenc is the only mpeg encoder i use. Tmpgenc has been the only mpeg encoder for me since ver 1.2 was the newest version.
vcd4ever.
AviSynth - JDL_ApplyRange() & FadeIn() Compatibility Issue?
By Typhoon859 in forum Video ConversionReplies: 18Last Post: 4th May 2009, 19:29 -
Compatibility issue between Cameo Grabster 200 and Vista
By nawp in forum Newbie / General discussionsReplies: 0Last Post: 8th Mar 2008, 09:12 -
Help! My DVP5960 has compatibility issue with Seagate FreeAgent 500GB drive
By agidol in forum DVD & Blu-ray PlayersReplies: 4Last Post: 26th Dec 2007, 08:50 -
Sound Card Compatibility with After Effects CS3 Issue...
By Angelus22 in forum EditingReplies: 1Last Post: 28th Oct 2007, 07:20 -
PAL + NTSC Compatibility Issue !?
By ells6363 in forum Newbie / General discussionsReplies: 7Last Post: 19th Jun 2007, 12:37
