Hi,
I use DRU500AX, Nero latest version to backup my data files on Sony, Maxell, Fuji DVD-RW and DVD+RW medias.
After burning i cannot view the cd i burned on my Samsung DVD-ROM drive.
How do you guys burn Datat files and how do you close session?
I've used EZCD Creator 5 platinum and EZCD 6 with no problems. Can't help you with Nero.
Nero may be [more than likely is] your problem. I use Record Now Max which uses DLA [Drive Letter Access] and all you do is view and use the DVD+/-RW as if it were a big floppy [after formating for DLA] RE: drag and drop. Works well for me Pioneer DVR-105x2 HP 200ix2.
(;-{> Dd
Strength and Honor
www.dvd9to5.com
www.dvd9to5.com/forum/
"For every moment of truth there's confusion in life"
Black Sabbath/Ronnie James Dio -
Although Nero has been giving me terrible problems with DVD-Rs and DVD+Rs, it has never had a problem with DVD_/+RWs.
To make the DVD-RW (or +RW) readable on a DVD-ROM drive, you must have a closed session disk and the disk must preferably be an ISO or a UDF/ISO disk. If that is the case, then the DVD-ROM should be able to read the disk.
Are you certain that this DVD-ROM drive can read DVD-RWs? Most can but you may have the odd one. Try using the disk on other, recent models.The more I learn, the more I come to realize how little it is I know.
How do I backup data to CD or DVD and have the data encrypted?
By OM2 in forum Newbie / General discussionsReplies: 4Last Post: 6th Mar 2011, 18:53 -
Can't see data on a DVD-RW ! Please help!
By Icaro in forum MediaReplies: 10Last Post: 20th Jan 2011, 05:45 -
How to combine video data and audio data in realtime
By mudassar in forum Video Streaming DownloadingReplies: 0Last Post: 31st Aug 2010, 09:00 -
DVD Data Disc
By DuBsTaR in forum Newbie / General discussionsReplies: 2Last Post: 30th Sep 2009, 05:31 -
How do I transfer data into dvd.
By millyvanilly in forum Authoring (DVD)Replies: 8Last Post: 24th Jan 2009, 22:34
