I used Scenalyzer Live to capture analog video passed through my MiniDV camcorder and Firewire connection. That part worked fine, Scenalyzer captured the video using scene detection, meaning it saved each scene in its own file. So now I have an hour's worth of video saved in about 30+ files, all ranging in size from about 100MB to 2GB. Some of these clips are as short as a few seconds.
If I author them as is, each file becomes a chapter on the DVD, and I don't want that. So I have to join them, but I'd like to do it without having to reencode them. Can anyone suggest a way to join DV files w/out reencoding? I'm looking for a solution that will take minutes as opposed to hours.
TIA,
--Doug
I like joining with Video Studio 6. It uses a Storyboard, so I just drag and drop. It also has a smart renderer function, which makes the processing go faster.
Hello. -
I am not sure. Why not try the demo and see if you like the results?
Hello.
Joining two different sized video files
By nominalgrevious in forum Newbie / General discussionsReplies: 8Last Post: 7th Mar 2012, 16:38 -
BD / DVD Digital Video Quality as compared to Uncompressed RAW video.
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 5th Dec 2010, 08:11 -
Video Joining
By Simmons in forum Video ConversionReplies: 1Last Post: 27th Aug 2010, 09:39 -
What digital video format compares to Digital 8?
By jungleexplorer in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 21st Dec 2009, 15:00 -
Video Joining Help
By dbanga in forum Newbie / General discussionsReplies: 1Last Post: 17th Jun 2007, 10:39
