Does anyone know how to burn an ISO with Toast 5?
Yes, it's easy! Startup Toast 5 and with your mouse click and hold down "other' which is the far right box and choose ISO 9660. Drag your file to the middle box and hit burn!
I think he meant "How do you burn an ISO IMAGE FILE with toast 5?"
I'd like to know that too.
(And yes, I know I can extract the files and make cue/bins or XA images) -
Well, if it is a valid ISO or BIN image, you can just drag it onto Toast while you have 'Disc Image' selected from the 'Other' menu...
Although, I have found that some CUE/BIN images burn better using Missing Media Burner, especially when you need true bit-by-bit copying.Slaughtering the competition with amatuer-quality VCD authoring abilities... fear my non-l33t skillz.
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 13:42 -
m2ts to burn in Toast 11 (MAC) Issue
By Reesche in forum MacReplies: 3Last Post: 27th Sep 2011, 15:55 -
Toast 9 - Xvid - how can I burn with SRT file
By BattyRoy in forum MacReplies: 4Last Post: 22nd Sep 2009, 06:31 -
Cant burn Video TS in Toast
By 3lutz3toe in forum MacReplies: 21Last Post: 11th Sep 2009, 17:31 -
How to burn toast file in windows XP?
By yunakokimama in forum Authoring (DVD)Replies: 2Last Post: 12th Dec 2007, 18:01
