Can someone tell me whats wrong with my sony drive!? When I try to burn a dvd using veritas record now it says after a while, after tried to write lead-in, "Read error. error -10 in sector bla bla bla ...". Nero says "there is problem reading the disk do u want to contiune" and if I press yes the recording soon fails with a "power calibration error".
I had no problem what so ever burning the first 10 discs but then these errors started to encounter and now i can almost not burn any disk!! Someone got a clue what can be wrong!? Tried different fw and now im using 2.0e. Hope u got a good answer on my problem! btw nothing is written on the dvdr so they are still empty after the errors.
// rezze![]()
Results 1 to 9 of 9
Have you tried the "Sony DriveCheck Diagnostic Test" Utility which can be found at http://sony.storagesupport.com/dvdrw/dru500adwn.htm This is the Sony Utility that you're suppose to use to see if your drive is bad or not. This would tell you if your problem was hardware.
I had two sony DRU500AX nothing buy problem's I have PIONEER AO4 never have problem's
Possibly it is the brand of media you are using,i had very similar problems with pioneer A04 writer,pretty much the same error actually,i've found since then using different brands of dvd media has temporarily solved the problem,done 70 discs with no errors since then,but i know i will get errors again if i change back to the previous discs i was using.
im currently using Datawrite classix 2x
http://www.mobiltech-media.com/main.asp?Page=ShowItem&SecID=2&CatID=5&ProdID=869&ProdVersionID=882 -
I had that same "calibration error"
and I could not burn anything after that so I had to return mine for a new one.
Sony Optiarc DVD RW Drive writes but verify errors???
By bahjan in forum DVD & Blu-ray WritersReplies: 7Last Post: 6th Jan 2012, 09:33 -
Fed up with random Sony Vegas errors.
By TMC83 in forum EditingReplies: 2Last Post: 11th Aug 2011, 04:22 -
Rendering Errors in Sony Vegas 9 Platinum
By Sedvic in forum Video ConversionReplies: 2Last Post: 20th Mar 2009, 18:07 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 17:02 -
check a DVD for errors/read errors?
By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 11:53
