I just downloaded the Wallace and Gromit Cracking contraptions set, http://atomfilms.shockwave.com/af/spotlights/wallacegromit/ now it uses a license key that you get, thats fine with me, but I want to convert them so I can burn them to VCD and view them on my DVD player... however all the programs i've tried gives me an error when I try to convert them, any ideas?
Have Burner will Travel
You could use an old version of VirtualDub and convert to avi then encode to VCD. The old version is here - http://perso.wanadoo.fr/nomad/virtualdub13c.zip
Scrap the above, doesn't work. I used Asf Tools and extracted an avi and a wav but can't get the audio to sync, i'll keep trying though. -
What program did you use to pull the avi and wav out? I can only get it to play under Windows Media Player 9.... with the licensing thing.
Have Burner will Travel -
i just read the full lic details and you are not allowed to convert the format or get around the lic digital management rights ..
which does perhaps suck , but it does make this thread not per guidelines for posting ..
need help converting .asf to h264 .mp4
By hydra3333 in forum Video ConversionReplies: 3Last Post: 12th Sep 2010, 07:53 -
Converting into ASF [Optional Setting]
By ashkan_vpm2 in forum Video ConversionReplies: 0Last Post: 15th Feb 2010, 07:17 -
Audio & video sometimes desynchronized while converting DV to MPEG
By kb1985 in forum Newbie / General discussionsReplies: 0Last Post: 19th Oct 2008, 17:02 -
Converting & Importing Screenshots for MPEG Editing
By cyberboy in forum EditingReplies: 1Last Post: 6th Oct 2008, 04:44 -
converting asf to avi
By projecttemp in forum Video ConversionReplies: 2Last Post: 3rd Aug 2008, 08:40
