I have had trouble backing up 8 Mile using DVD Decrypter then DVD 95 Copy then Copy to DVD. I was wondering if anyone has had the same problem and might have any solutions.
Results 1 to 13 of 13
it will have menus and everything but when i press play it will freeze at the rating screen where it says its r rated. so i tried selecting scenes and there r no numbers or descriptions and it wont let me selct them
Sounds like an OLD problem i used to have
before these programs came out w/ ifoedit,
i would forget to "get vts sectors"...anyway
to do that with 925? -
I did 8 mile couple of days ago. I used doom9.org DVD-9 -> 2 DVD±R guide since it can't fit to one disk without re-encoding.
Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
my format is to use; smart ripper->select all file, dvd95copy->just the english 6ch (why in the hell you need english subtitles?), and lastly burn it with nero!!. simple and works great, i don't really care about the qualityjust the movie(s)
Maybe I am deaf or English is not my first language....Originally Posted by artpoun79
Used DVD Decrypter, DVD2ONE & RecordNow Max and everything worked great.
I used the Guide that BarryHL put together on this website.Nutty1 -
O best way to go with 8 mile is get instantcopy and dvd decrypter. decrypt the DVD (make sure you select all the files) then in instant copy copy everythin but the DTS track. My copy turned out just as perfect as the origional
help fellow comic book nerds! - RE: Mile High Comics Black Friday
By Xylob the Destroyer in forum Off topicReplies: 0Last Post: 22nd Nov 2007, 08:36
