Hi, just wondering if n e 1 could explain how i add menus to a dvdr that has 2 films on it, have reduced the size of both films to fit onto 1 dvdr, but not sure how to get them to dvdr with menus so that u can pick wat film to watch. N e help would b much appreciated
Many Thanx
Max
Take a look at the links to the left under Author. Basically you need to author the DVD with a new menu that points to both videos.
If you can get the movies into a video and audio stream for both then its its easy to do inside DVDMaestro. Thats how I would do it.
ok, had a look through author, can't seem to find n e thing about 2 films to 1 dvdr
Many Thanx
Max -
Originally Posted by md_mushroom
If you want suggestions for such programs, I can only recommend ULEAD DVD Workshop. It comes with a 30 day free trial. Check it out if you like it. You might. It can also capture video. You can put menus with (or without) pre-made templates and use a frame of your movie as a thumbnail.
Look at the other tools (not guides) in DVD Authoring for something else also.The more I learn, the more I come to realize how little it is I know.
adding menus
By tfrost2002 in forum Newbie / General discussionsReplies: 5Last Post: 13th Nov 2011, 15:10 -
Adding menus to a remuxed Blu-Ray
By ITISRAVI in forum Blu-ray RippingReplies: 0Last Post: 17th Nov 2010, 09:27 -
putting all of my Blu-Ray & SD DVD to hard drive?
By neworldman in forum Blu-ray RippingReplies: 16Last Post: 17th Mar 2010, 09:21 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 13th Mar 2008, 23:19 -
Adding a subtitle for a DVDR
By rotchild in forum SubtitleReplies: 5Last Post: 28th Jan 2008, 11:07
