Hello, I have an old (3yrs old) WinTV card that I tried using to capture video from a VHS. All sorts of problems beyond my understanding. Did some research and have come to eventually buy the ASUS TV Tuner Card. I am currently running a Pentium 4 2.53 Ghz processor with 1gb of pc2700 ram and a Radeon 128bit (32mb) video card. My question is, would this be sufficient enough to capture straight from video? Or is there a better method. I really want to run the capturing on my Pentium 3 1ghz processor. Also, can I still use my WinTV card to do video capturing since I have it?
Yes to both. The system should be adequate, and yes you can use your old capture card. You should be able to use VirtualDub to capture. Read the newbie section to find guides on capturing and converting video.
Impossible to see the future is. The Dark Side clouds everything...
Problems with capturing using ION VCR 2 PC
By mostly_useless in forum Capturing and VCRReplies: 0Last Post: 21st Dec 2011, 18:16 -
Looking for Good VCR for Capturing
By zerowalker in forum Capturing and VCRReplies: 0Last Post: 28th Nov 2011, 17:56 -
Need Help Urgently Capturing from SVHS VCR
By Hairykiore in forum Video Streaming DownloadingReplies: 9Last Post: 4th Aug 2011, 19:26 -
VCR capturing question?
By s3r19lk1ll3r in forum Capturing and VCRReplies: 1Last Post: 17th Oct 2010, 21:26 -
Having problems capturing from VCR
By Confused Chimp in forum Newbie / General discussionsReplies: 5Last Post: 29th May 2007, 02:41
