hi guys
i just installed winxp on my new pc, and almost everything is running fine
except that i can't seem to get the pc to detect the dv camera when it's plugged in, i used to use win98se and it worked in terms of detecting the camera, got lots of dropped frames though, hence the new pc.
but on xp it doesn't work
i don't have a ti driver, the driver is via ohci compliant 1394 driver (2001)
i've tried this with premiere 6 and also with my
leadtek winfast capture software, but neither detect the dv camera
i have turned the camera on before the os starts, in vcr mode
i've been to the adobe web site, but the support pages didn't cover anything i didn't already know or try
thanks for any help
ok
it is a via vt6306 chipset
my mboard uses the sis 648 chipset
are there any known issues with using the via
chipset with the sis chipset
i've been to the via web site
but it is useless
thanks again
Looking for capture device, is this what I need?
By V Bot in forum Capturing and VCRReplies: 3Last Post: 21st Apr 2012, 10:16 -
Capture device
By ingeborgdot in forum Capturing and VCRReplies: 7Last Post: 11th Sep 2011, 21:02 -
Recommendation of Video Capture Software for WinXP
By opey in forum Capturing and VCRReplies: 3Last Post: 4th May 2010, 03:16 -
Video Capture with Mplayer, Mencoder or ffmpeg under Winxp. Is it possible?
By gll99 in forum Capturing and VCRReplies: 0Last Post: 11th Sep 2008, 19:00 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 05:31
