  1. i`m using dvd2one v1.1.1, and when i try and playback any copy on my philips 711 dvd it freezes about a third or so though the disc. every time. very annoying (and expensive as i`m going through discs like there`s no tomorrow). using pionner a03 and various disc brands. any help? (my apologies to those who have seen this query on the dvd2one forum, but have to share this problem further).
  2. what firmware does your a03 have?
    u might need to upgade to latest if u dont have it
    check out http://www.geocities.com/eatin_sammiches/sprucecreations.html to download additonal buttons and backgrounds for SPRUCE-UP menu creation
  3. what software are you using to burn and what player is it????
  4. using pioneer a03 f/w 2.0 with prassi to burn. hope this helps!
    Dec 2002
    1) Does it play on your PC?
    2) Can you skip the chapter to the next chapter?
    3) Try the disk on a friends machine?
    4) Try burning with Nero or RecordNow.
    5) Mount an image with Daemon tools of the DVDR and see if it plays (this is testing for a flaw in teh disk/burning).
    Is it always the same place? Same movie or different?
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
  6. after you have ran the movie through DVD2ONE did you get VTS_SECTORS with IFO_EDIT, I found this to be the best way to use that program, although I only use that program for my sons movies.
    Thanks alot,
    dreadogg
