How can i find out write speed if it does not tell me on the front of the blank dvd-r tried nero info tool but could not find anything
im using
dvd decrypter
dvd2one
recordnow max
i bought a sample pack from online and half dont have the speed on the disc
i have a sony dru500ax
the discs have their max speed written into their ID code, you will only be able to select the speeds they work at in nero. i.e. a 2X media, you will have the option of 2X or 1X writing, a 1X media you will only see 1X listed.
D oes this apply to recordnow max also as i think i seem to remember a drop down with write speed
what if i choose 4x and the disc is a 2x will it ruin the disc or will i get a warning
or will it only give me the option of what i have and under -
as i said, you will only be able to select the speeds your disc supports, this applies to -all- burning software. if you cast your eyes to the left you will see a DVD media section. you can run a simple program to accurately identify any dvd writable discs in your drive, and then look up what other users have experienced with the same disc.
How can I increase DVD/Blu ray write speed?
By gsingh13 in forum DVD & Blu-ray WritersReplies: 1Last Post: 3rd Jul 2011, 22:47 -
How do I speed up my video to 10X speed?
By mileena in forum Newbie / General discussionsReplies: 9Last Post: 27th Aug 2010, 14:24 -
multi LG Gh22np20 write speed issues
By mistermofo in forum DVD & Blu-ray WritersReplies: 5Last Post: 6th Jan 2010, 19:37 -
Finding out write speed
By BrokenOne in forum DVD & Blu-ray WritersReplies: 2Last Post: 31st May 2008, 02:40 -
problem with write speed of dvd burner`
By mr-scarface in forum DVD & Blu-ray WritersReplies: 4Last Post: 20th Sep 2007, 13:58
