Greets All.
I have obtained a copy of Prassi Primo, as I have been informed that it is the top DVD burning Prog. However, I cannot get it to recognise my SONY DRU-500A
Has anyone else had this problem or is it just me?
Help me please .....
Thanks on advance.![]()
go to http://www.prassieurope.com/
and download the pxengine update as this adds support for more recent drives -
Hi spooki
No way ... as you can see in the list of device recognition the only SONY recorder are the DRU-110 and DRU-120. Aniway I have made the download but the problem is still there. The DRU-500 is as Slave at the second IDE .. can it be the problem???
Regards -
your problem is that you got primo..primo won't work with the dru-500a or ax...you have to get recordnowmax 4.5
I was using Nero and have had all sorts of problems.
The DRU500A comes with RecordNow and you can download a free upgrade to RecordNowDX. I have it and used it with the drive. Did 3 burns already without a problem. Will be using RecordNowDX from now on.The more I learn, the more I come to realize how little it is I know.
/Sony DRU-190A problem
By Quadzilla in forum DVD & Blu-ray WritersReplies: 22Last Post: 7th May 2009, 14:10 -
Firewire External Enclosure for Sony DRU-500A. Help choose..
By donpedro in forum DVD & Blu-ray WritersReplies: 79Last Post: 25th May 2008, 11:52 -
Sony DRU 800A Problems burning??
By khronos000 in forum Newbie / General discussionsReplies: 4Last Post: 17th Sep 2007, 17:40 -
Sony DRU-810A question...
By bamabluebird in forum DVD & Blu-ray WritersReplies: 4Last Post: 10th Jul 2007, 10:21 -
Sony DVD RW DRU-830A
By bjswitz in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th May 2007, 08:41
