  1. What application can I use to extract an image from a DVD, I was using YADE, it allows you preview what you are going to save, but does not seem to work with some DVD's.
    What I am trying to do is save the Menu images so that I can rebuild them in DVDSP.
    Any idea?
    EarlyGrace
    Feb 2003
    Bloomington-Normal
    No clue. I will look into it though.
    Interesting...
  3. Most menu backgrounds can be separated out as a title using OSEX. You can load the file into Quicktime, and export a still .pct file that works well for menus. It doesn't preserve the hotspots, but you get the basic image.
