I have captured 2 hours of DV Type 1 video from my Sony TRV350. If I cut, say 50 clips out of the two hours, and I create a computer file using the same settings as the captured video, will the PC files of these clips be the exact same quality of the source capture or will I lose any quality?
Especially if I use them again in a new project?
TIA!
As long as you don't re-encode, there is no quality loss.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
I use Ulead VS 6.02 and 7.0 when I do this. Ulead goes through the "render" routine, but since I am using the exact same settings as I captured with, to save a PC file (AVI), I think it is just "pulling" the clips from the source (2 hour) video file.
Am I correct in assuming this? I know what assuming does?
Thanx. -
If you have 2hrs of DV, edit it down to 1hr, export as DV, you get the same quality as before. It simply copies the information.
Make sure you export as DV. I do not use Ulead so I couldn't tell if that is what you picked.
MKV & Adobe premiere: Best method to import without quality loss
By libjoe67 in forum EditingReplies: 34Last Post: 19th May 2012, 16:34 -
Best method to decode DTS WITHOUT QUALITY LOSS?
By m1ndripper in forum AudioReplies: 12Last Post: 22nd Nov 2009, 17:07 -
mkvmerge - no quality loss?
By gustav32 in forum DVD RippingReplies: 1Last Post: 20th May 2009, 15:56 -
Encoder with no quality loss
By JamesDV in forum MacReplies: 25Last Post: 8th Apr 2009, 12:01 -
video quality loss
By majax79 in forum Video ConversionReplies: 2Last Post: 24th May 2008, 02:03
