Hi
Some time ago I converted a film to mpeg and thought I had flipped it also (I used ffdshow as it was upside down).
The problem now is that when I went to watch it the other night it was still upside down and now only have it on vcd.
What I need to know is how do I convert the vcd back to an mpeg file, so that I can re-encode it hopefully with the flip option working.
I have managed to convert it to a mpeg with tmpgenc, but it has not flipped and ffdshow did not activate itself when converting.
The way I converted it was to copy the dat file onto my computer and convert the usual way with tmpgenc.
I have also tried re-encoding it with winoncd (as this usually activates the ffdshow programme), but it did not work.
Thanks in advance for any help.
Take care
Scarlet
You could use one of the Frameservers (VirtualDub or AviSynth) to serve the MPG to TMPGenc, both have a 'flip vertical' (or is it horizontal?) filter which should turn it up the right way.
Hi
Thanks for your reply.
Just a couple of questions though.
Would I copy the dat file over to my hard drive and then convert using virtualdub (I have the programme but have never used it).
If so how would I save it as an mpeg as the only options I see are for avi.
Sorry to sound dumb, but I am used to just being able to use tmpgenc or winoncd or nero.
Thanks in advance
Scarlet -
When I make SVCDs the MPEG files are renamed but remain on the disk in a folder called MPEG2. Is there no MPEG folder on a VCD?
converting MPEG-TS to MPEG-PS (from a Noontec V9)
By ninereeds in forum Video ConversionReplies: 2Last Post: 28th Jul 2010, 11:17 -
Quicktime parse error converting mpeg-1 muxed to DV or mpeg 4
By jglass in forum Newbie / General discussionsReplies: 0Last Post: 15th Jun 2008, 21:51 -
Problem converting audio of VCD MPEG-1 to author DVDs
By Greycat in forum Video ConversionReplies: 6Last Post: 16th Jan 2008, 17:28 -
This is a minefield! (converting mpeg to mpeg for DVD)
By uth in forum LinuxReplies: 29Last Post: 18th Nov 2007, 16:04 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54
