  1. i am trying to convert a svcd file to a vcd, using the guide here https://www.videohelp.com/mpeg2tovcd.htm it says that when done i should have two files like this test MPA T01 DELAY -86.mpa
    test.d2v
    however when i try it i only ever get the .d2v file but never the .mpa file!!!! what am i doing wrong? thanks
  2. do you have it set on track 1?
  3. no, should i have?
  4. that is what it was, thanks for the reply, this forums great, havent had a prob, that u lot couldnt fix yet!who knows another couple of years, and i might be able to hand out some advice!1 lol
