Does anyone know if you can change the aspect ratio of an mpeg2 video without re-encoding it?
I have the impression that the aspect ratio is just an atribute in the file somewhere.
Mostly Harmless
Yes you are correct. You can do what you want with pulldown.exe. I suggest you use the gui.
Or DVDPatcher, or Restream. Some authoring packages scan the whole file and it apparently gets repeated down the line, so you have to run DVDPatcher throughout the file. Other authoring programs only look at the first header and you only need to change it there for those.
The more I learn, the more I come to realize how little it is I know. -
Originally Posted by Kamikaze47
Well the source makes no difference if you are just changing the aspect ratio flags, but that is a good point. If your source is 29.97fps or 25fps than you have to tell pulldown not to insert the pulldown flags, because it does so by default.
WMV Aspect Ratio Changing?
By Crazyj32 in forum Video ConversionReplies: 11Last Post: 10th Aug 2014, 06:53 -
Changing a DVD's Aspect Ratio
By soneman in forum Authoring (DVD)Replies: 11Last Post: 8th Sep 2009, 18:18 -
Changing aspect ratio.
By Lyceum in forum EditingReplies: 5Last Post: 28th May 2009, 12:19 -
Changing aspect ratio?
By Marlow in forum Video ConversionReplies: 2Last Post: 5th Apr 2009, 05:40 -
Changing an aspect ratio on DIVX
By diablo_jones999 in forum Video ConversionReplies: 13Last Post: 29th May 2007, 11:53
