I know this info is probably here somewhere but I want to be absolutely clear.
The frame size for standard ntsc is 352 x 240 as I understand it, My question is, Is this the only frame size you can use to be able to play on standalone dvd player on your tv or does it depend on the dvd player?
For VCD: Anything outside 352x240 for NTSC video would be out of spec and is not guaranteed to play on anything. You can always try - that is callex XVCD if it is out of spec but modtly VCD (X for extended).
Now some VCD/DVD players play raw MPEGs - just burn a MPEG movie as data and it reads it like the MP3 players by displaying filenames & you can pick. BUT those players are rare (see the players list at left).Panasonic DMR-ES45VS, keep those discs a burnin' -
Ok thanks kitty,, just wanted to clear that up because I have been having problems with a couple movies and another moderator pointed out that my frame size was on one in an earlier question was non standard and after looking I've discovered that all the ones I am having problems with are this way
So thanks again for the info
Frame Size
By kamranj in forum Newbie / General discussionsReplies: 18Last Post: 9th Jan 2011, 18:59 -
Upconverting SD to HD frame size...
By bkelly36 in forum MacReplies: 3Last Post: 24th Oct 2010, 17:31 -
Frame Size. What effect does it have?
By happydog500 in forum Capturing and VCRReplies: 7Last Post: 12th Mar 2009, 00:21 -
Frame size in HDVSplit
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 5th May 2008, 00:36 -
How to alter frame size?
By elite123 in forum Newbie / General discussionsReplies: 4Last Post: 20th Aug 2007, 18:43
