Results 1 to 28 of 28
  1. Lost Will Hay's Avatar
    Oct 2002
    Buggleskelly Railway St.
    I have a Pioneer 105 dvd-rom drive which is very slow to rip and been trouble to set to region free.
    I'm gonna' replace it so can anyone recommend a drive in the UK which is quick to rip and easy to set to region free?
    I hear lite-on are great (my cdr burner is lite-on), anyone confirm this?
    Thanks,
    Will
    tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
    Jan 2003
    In the bath
    Lite-On are indeed great. I don't think there is a faster drive for ripping DVDs out there (correct me if I am wrong). They are also very cheap, around £32 from www.dabs.com so you can't go wrong
  3. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    Liteon are good as mine gets upto 8-9X
  4. Lost Will Hay's Avatar
    Oct 2002
    Thanks guys.
    So it would fair to say any lite-on, whatever the model, yes?
    Are these easy to region free?
    Will
  5. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
  6. Member SaSi's Avatar
    Jan 2003
    Hellas
    I have a Pioneer 116 and have also tried a 119 (new model) at a friend. I have flashed the f/w on the 116 and made it region free.
    The 116 rips at an average of 8.5x most of the DVD. A few only go as fast as 7x average. All figures with DVDDecrypter and file mode.
    The 119 is more or less the same (only did 2-3 rips with that). I don't know if a RPC patch is available for that, but even if it doesn't there will be very soon.
    The more I learn, the more I come to realize how little it is I know.
  7. Lost Will Hay's Avatar
    Oct 2002
    I've just flased the 105s - error message.
    I created a boot disk downloaded from http://forum.rpc1.org/dl_all.php and stored the unzipped firmware (105f_122) on my ntfs partition.
    For some reason my primary hdd wasn't shown via the boot disk.
    I got as far as the end with a success message but the following error was above that:
    FILE CREATION ERROR
    <-[2J
    NOW RUNNING MS-DOS VER 8.00
    BUFFER ALLOCATE ERROR
    Anyone know what I did wrong?
    Will
  8. You have to put the fw files also on the floppy and just run the upgrade.bat.
    A DOS disk cannot access files on an NTFS file system (your harddisk).
    For the DVD-ROM: I have an EPO 8216 that is not region protected right out of the box! Rips in DVDDecrypter show 9.3x average / 12.3 max speed.
    Go in the UK's Yahoo and look locally for +Epo +DVD and you should be able to find some sources for purchasing one.
  9. Lost Will Hay's Avatar
    Oct 2002
    I see.
    So by adding the firware to the boot disk and running from there (it's a cd - I'm having a problem with my floppy drive) I'll solve the problem.
    Okay, thanks.
    I'll obviously have to run from a cdrom drive other than the one I flash, yes?
    Will
  10. Correct!
    And no disc at all in the Pionieer burner when flashing. It will fail to flash if you have a disc in it.
  11. Lost Will Hay's Avatar
    Oct 2002
    Just tried it
    I ran the boot disk in my dvd drive (G) and the firmware in my cdrw (H).
    I ran the following command at the H:\ prompt:
    CD H:\105F_122 (105F_122 being the unzipped file containing the firware on the cd) and then 'AUTOEXEC'.
    Seemed to run through fine, ie do you want to continue' etc. but then same error message as before
    Anyone any ideas?
    Thanks,
    Will
    Jan 2003
    the wirral uk
    If you want to ask a question please start a new topic
    -tgpo
  13. Sorry - but you seem to be very unexperienced with the "dark side" OS
    Also, you should have read the readme.txt provided with the zipped files.
    You have to type UP105 which is the batch file for the fw update when in the fw directory.
  14. Lost Will Hay's Avatar
    Oct 2002
    Yes, I am.
    I did, as well as printing the full instructions from the source site of the firmware....
    Erm, I don't think so.
    Extract of instructions for this firmware update http://www.geocities.com/gibler666/index.html
    ...."You will be running the AUTOEXEC.BAT script and NOT the upg5a.exe program directly".
  15. Lost Will Hay's Avatar
    Oct 2002
    ...I have an EPO 8216 that is not region protected right out of the box! Rips in DVDDecrypter show 9.3x average / 12.3 max speed. Go in the UK's Yahoo and look locally for +Epo +DVD and you should be able to find some sources for purchasing one.
    I'll check it out, thanks.
    W.
  16. Lost Will Hay's Avatar
    Oct 2002
    This is the batch file 'AUTOEXEC'
    @Echo off
    Cls
    Type Readme.txt
    Echo ÿ
    Echo Press Ctrl-Break if you want to EXIT, or any key to CONTINUE!!!
    Pause >Nul
    Echo ÿ
    Echo Last chance to EXIT (Ctrl-Break), or press any key if you are READY!!!
    Pause >Nul
    call upg5a.exe /2 105F_122.HEX
    Echo ÿ
    Echo ÿ
    Echo *** Firmware upgrade sequence Done! ***
    Echo ÿ
    Echo Remove this Boot Disk, and restart your PC !
    Echo --------------------------------------------
    The files contained in the batch file are:
    105F_122.hex
    AUTOEXEC (batch file)
    UPG5A.exe
  17. I have a pioneer dvd-105 and it rips up to about 12x with an average of around 7x so it shouldn't be the drive,
    Are you sure you have aspi drivers installed and DMA switched on ?.
  18. Lost Will Hay's Avatar
    Oct 2002
    I rip at a maximum of x2/x2.5
    I have DMA turned on but how do I determine if the aspi drivers are installed - these mean nothing to me
    Thanks,
    Will
  19. download http://www.doom9.org/Soft21/SupportUtils/forceaspi17.rar
    extract the files and run instapi.bat and it will install the aspi drivers, without these a lot of people report slow ripping speeds.
    you can also use
    http://www.doom9.org/Soft21/SupportUtils/aspichk.rar
    this checks which aspi drivers you have installed.
  20. Lost Will Hay's Avatar
    Oct 2002
    I keep getting this page when I try the links:
    http://www.doom9.org/index.html?/leech.htm
    Will
  21. If you have a firewall installed you will probably have to disable it when you click on the link otherwise you get the anti leech thing.
    if you still have problems go to www.doom9.org select downloads and then i think it's under support utils
  22. Lost Will Hay's Avatar
    Oct 2002
    Yeah, tried that still got it!
    Very strange!
    Yep, got it, many thanks
    Will
  23. Lost Will Hay's Avatar
    Oct 2002
    aspi wasn't installed correctly.
    Just downloaded and run, will test a rip now and report back in the morning!
    Thanks again,
    Will
  24. Lost Will Hay's Avatar
    Oct 2002
    Thanks again,
    Will
    Ripping MIB at x 1.8 average
    Still, if I can region-free I'll be a happy man!
    Will
  25. Hope it works as the 105 is a really good and quick ripping drive
  26. Lost Will Hay's Avatar
    Oct 2002
    Got it working!!!!
    Now region free and ripping at x7 as I type.
    Thanks for your help,
    Will
  27. Member marvel2020's Avatar
    Mar 2001
    Vorlon Home World
    Silky31 checkout the following link...
    https://www.videohelp.com/forum/viewtopic.php?t=147420&highlight=
    This is a post that i replied on about the liteon DVD Rom drives, if you scroll down abit, you will see some ripping speed tests that i done using my Lite-On 163D DVD Rom Drive.
    I Have Always Been Here
    Toshiba Regza 37Z3030D, Toshiba HD XE1 + EP-10 ( Both Multiregioned), Samsung BD-P1500 Blu Ray. OPPO DV-983H
  28. Lost Will Hay's Avatar
    Oct 2002
    Thanks man, appreciate that.
    I'll check it out.
    Will
