I am trying to create a Disc Image in SpruceUp just as I've done a thousand times before. Only this time, it completely compiles the image, then fails when it begins to write it to the hard drive. I get an error pop-up box that says "Operation Completed Successfully" only it has "Error" as the title of the pop-up!!!!!!!I'm desparate for help here. I've tried rebooting, changing the name of the Disc Image, changing the location I am saving it to. All without success.
Thanks for your help........
i had similar probs when first used spruce up.it would create image and when i went to check file size it was 0mb!!!
i tried uninstalling the prog and did a re-install and touch wood that seemed to have solved the problem.
apart from that i cant say why it really happened. i hope this helps.
let me know how you go on.
desperate help needed with Philips DVP3982
By DaneClark in forum DVD & Blu-ray PlayersReplies: 3Last Post: 2nd Jul 2010, 23:56 -
Nero Disc Image?
By angryassdrummer in forum Video ConversionReplies: 2Last Post: 1st Jul 2010, 11:36 -
DVD to MPG/AVI/H264 for editing - desperate help needed
By BertRito in forum Newbie / General discussionsReplies: 19Last Post: 18th May 2010, 00:46 -
Proper FLV Encoder needed - getting desperate!
By vk_dk in forum Video ConversionReplies: 3Last Post: 28th Feb 2009, 10:43 -
disk image advice needed
By rhegedus in forum MacReplies: 3Last Post: 31st Aug 2008, 11:52
