Hi all,
Ulead VS5 keeps giving me errors and wont work. Everytime I start a new project for capture it gives me errors like:
"Setting the capture preview rate error . Failed to build a preview graph"
and;
"Setting the capture preview mode error check if your capture device is working properly. Failed to build a preview gragh".
Does anyone know what this means and how to fix?
It seems to only work at RGB 16 320x240 no higher.
Also, It won't let me choose YUY2 it says it can't be used as codec template. I have downloaded directx 9 and all the latest P4 & XP patches and still no go. Whats going on?
All comments appreciated.
Trash VS 5.0 and get VS 7.0. I never had problems with VS 6.0 or thenew VS 7.0. Many performance improvements have been made, including the use of codecs.
help with Ulead videoStudio?
By wamit in forum Capturing and VCRReplies: 4Last Post: 24th Apr 2009, 08:27 -
ULEAD VideoStudio trim
By dcmoser1952 in forum EditingReplies: 3Last Post: 24th Feb 2009, 14:43 -
rmv Plugin for Ulead VideoStudio
By Metalgod in forum Newbie / General discussionsReplies: 1Last Post: 18th Jun 2008, 22:22 -
Ulead VideoStudio 10 Manual Appendix
By cedricwyn in forum Newbie / General discussionsReplies: 0Last Post: 30th Jan 2008, 22:40 -
Ulead VideoStudio 11 on Vista
By run1492 in forum Authoring (DVD)Replies: 2Last Post: 10th Jul 2007, 17:21
