A search did not give me adequete results though this question must have been asked sometime or other. My question is:
How many times can you write and re-write on DVD/RW (+RW or -RW) and CR/RW? Will the media degrade over repeated re-writes?
Thanks.
*** My computer can beat me at chess, but is no match when it comes to kick-boxing. ***
I have been using re-writables for some years. I have found that the number of re-writes depends on the quality of the media (to the extent that brand name equals quality).
I have lost a couple of CDRWs after 15-20 rewrites. These were old, 4x media that I would anyway not use anymore. I have been using some High Speed 10x TDK CDRWs (two) for some time and I have perhaps re-written them more than 50 times so far.
With DVD+RW and DVD-RW, specifications state more than 1000 rewrites are possible (in contrast to DVD-RAM that allows thousands of rewrites). My experience so far is as follows:
I have been using 3 DVD+RW disks, one from SONY that came with the recorder and 2 x Sentinel. I must have rewritten them more than 100 times each (I use them for proof recording and experimenting) over the last 3 months and no problems.
The only problem I have had is with one of the disks that has been slightly "abused" and has collected dust and scratches. I sometimes get a "Power calibration Error" from the drive when erasing prior to re-writing. I clean the disk with water and soap, wipe it dry and records just fine.
I don't have much experience with DVD-RW as I have not re-recorded them often. They are rated at 1x and it's a drag to record on them, so I prefer +RWs. Again, I have never had any problem with 2 x Maxell DVD-RW and 1xTDK and I have re-recorded them more than 5-6 times each.The more I learn, the more I come to realize how little it is I know. -
I posted this question some time ago and can't seem to get a response. I am sure it has been asked before, but I can't find it. Can you explain to me the difference between DVD -R DVD+R and DVD-RW DVD+RW. I know the difference between R (read only) and RW (Red and Write, but I do not have a clue about the - and +.
Diane
I have heard over 1000. I have one disc that I have used about 100 times so far.
These are pretty good guidelines to go by, assuming high quality media and burners, good storage conditions, no handling wear and tear:
CD-ROM, DVD-ROM -- 0 times (of course) 8)
CD-R,DVD-R,DVD+R -- 1 time (not counting multi-session), 99 times (counting multisession-think "track count")
CD-RW, DVD-RW, DVD+RW -- ~1000 times (including multisession)
DVD-RAM -- ~100,000 times (including multisession, if that's possible for RAM)
Scott -
You're off topic on this. Check the glossary for an explanation but they're basically two different (and mutually incompatible) recordable DVD types.Originally Posted by Mistress Diana"Art is making something out of nothing and selling it." - Frank Zappa
Sony Optiarc DVD RW Drive writes but verify errors???
By bahjan in forum DVD & Blu-ray WritersReplies: 7Last Post: 6th Jan 2012, 09:33 -
ffmpeg Number of stream maps must match number of output streams
By tmiller_15 in forum Blu-ray RippingReplies: 1Last Post: 13th Nov 2010, 07:20 -
DVD Burner sudenly read/writes at less than 1x speed
By Megahurts in forum ComputerReplies: 1Last Post: 22nd Apr 2009, 22:47 -
Toshiba's Vardia RD-A301 writes HD DVD content to DVDs
By roma_turok in forum Latest Video NewsReplies: 0Last Post: 31st Oct 2007, 03:56 -
NEC ND-3520A writes DVD's, which it cannot read
By Ruut in forum Newbie / General discussionsReplies: 1Last Post: 24th Sep 2007, 13:36
