Hello, I have a question regarding an unusual frame rate. I've converted a number of NTSC film files succesfuly without a glitch but came up with one lately that gives me freezing errors in my DVD player.
This is a DIVX with an unusual NTSC film frame rate: 23.996. My previous conversion was 23.976 with many freeze errors. My question is, would I be stuck with them, or would I be better off at 24fps?
I know it's not my player as it handles anything you throw into it. It just seems to me this is a frame rate just a little too outside standard NTSC film to be played smoothly at 23.976 even though it IS an NTSC film.
Any suggestions would be appreciated. Thanks.
Jack
Check this page : https://www.videohelp.com/forum/userguides/78178.php
If using TMPGEnc, check the "do not framerate conversion" box on the advanced part of the mpeg template settings. Encode video only.
If using CCE, create an AviSynth file (assuming that you have Avisynth installed), and copy and paste this:
#Start copy
AVISource("DRIVE:\PATH\AVI NAME.avi",False)
ConvertToYUY2()
AssumeFPS(23.976,True)
BicubicResize(480,480,0.0,0.6)
ResampleAudio(44100)
#End copy
Changing for your different format:
VCD: BicubicResize(352,240,0.0,0.6)
CVD: BicubicResize(352,480,0.0,0.6)
Load this .avs file into CCE, right-click and edit. Uncheck the audio box. Encode as normal.
Now for the audio:
If it's a stereo input, use BeSweet's overall track adjustment setting. Check the box for "Change frame rate from" 23.996 "to" 23.976.
Set bitrate under "2LAME"
Set sample rate under "SSRC"
Press "BeSweet"
Click "WAV to MP2"
Multiplex with MPV,M1V, or M2V.
If it's mono audio, load avi into Vdub and save uncompressed wav. Make an AviSynth file and copy and paste this:
#Start copy
WAVSource("DRIVE:\PATH\WAV NAME.wav")
ResampleAudio(Round(44100 * (23.996 / 23.976)))
AssumeSampleRate(44100)
#End copy
Load new audio .avs into audio source of TMPGEnc. Encode audio only after setting bitrate.
And when your done, you should have a 23.976 mpeg in full audio synch.
Also check this site:
http://www.geocities.com/xesdeeni2001/StandardsConversion/index.html#PALVCD2NTSCFilmVCD
Hope this works for you.
MKV with Variable Framerate convert to MP4 problem
By beaniekapp in forum Video ConversionReplies: 12Last Post: 4th Jul 2010, 08:44 -
HELP - MKV reference framerate change problem
By danielo in forum Video ConversionReplies: 5Last Post: 20th Aug 2009, 06:22 -
Problem when converting to High Quality framerate
By hzgg2 in forum EditingReplies: 3Last Post: 30th Aug 2008, 17:14 -
Framerate problem when muxing
By baconharvester in forum EditingReplies: 3Last Post: 17th Sep 2007, 18:35 -
converting framerate problem
By Shaorin in forum Newbie / General discussionsReplies: 0Last Post: 3rd Jun 2007, 00:00
