    Jan 2003
    Dallas, Texas
    My Cd Burner is a Samsung SV4012H. It came with amy Emachine Computer. I have a 1.8 ghz processor and WinXP. My Problem is that my cd burner doesn't burn at 40x any more. I mean it says 40x but it takes like 8 or 9 minutes. When I first got the PC it was burning good, it only took about 3 minutes to burn a cd. Recorder Buffer Level / State goes up and down when it used to stay at around 98%. Now it goes from 15 to 90. I don't know what the problem is but I did overburn two cds. Did that mess up my cd burner? Does anybody know?
    Aug 2001
    Dallas, Texas; U.S.A.
    Al-eye,
    I have the same problem, did you check to make sure that DMA was turned on? That is the main reason this happens. Hope this helps.
    -Epi
    Jan 2003
    Dallas, Texas
    I'm sorry but what is DMA? And how do I turn it on? Thanx
    Aug 2001
    What OS are you running on your computer?
    -Epi
    Jan 2003
    Dallas, Texas
    Windows XP
