  1. Hi,
    I usually don't do DVD to VCD but after a friend of mine asked me to I tried to make one with DVD2SVCD and it keeps freezing on me after a while. "Task Manager" says "Program not responding". Tried Easy VCD the same thing. Any ideas what do I miss?
    Cheers
    Apr 2003
    Union City, CA
    Look in the Log file. Something in your setting most likely did not work and the DVD2SVCD...frooze..
    It happened to me once when I had the done something wrong with my subs menu..
    The log file will tell you at which stage you started to get 'Not responding' that should give you a clue..
    shuq
