I should have been satisfied with the quality of the movie that I recently encoded but I kept try to change things and add filters and now after I encode avi to dvd and try to view on media player there is a huge green bar underneath at the bottom of the movie. I'm wondering if I change parameters in the set up do I have to create a new *.vaf before reencoding or if I screwed up cce. Any suggestions would be apreciated.
Thanks in advance,
Results 1 to 1 of 1
This is so much fun!
Green Bar at bottom problem solved!
By DeniseAck in forum Capturing and VCRReplies: 0Last Post: 9th Aug 2011, 18:19 -
Black bar on bottom of Windows Media Player 11
By Jynx980 in forum Software PlayingReplies: 2Last Post: 1st Nov 2009, 10:58 -
Capture analogue with 720x576 has tiny horizontal bar at bottom
By ManUtdFans in forum Capturing and VCRReplies: 15Last Post: 21st Jan 2009, 13:12 -
green vertical bar on left, purple verticle bar on right, source B&W VH
By lipwak in forum DVD & Blu-ray RecordersReplies: 0Last Post: 8th Jul 2008, 21:29 -
Green bar on bottom and right side of divx movie
By gthorley in forum Software PlayingReplies: 2Last Post: 19th Aug 2007, 14:39
