i have tried using claddvdxp2.0 and smartripper to rip dvds and it works
(the new claddvdxp2.98 beta didnt work for me) ... but when using
dvd2avi trying to frameserve i dont get a wav file only the d2v file ... i
have been using the tutorials on this site ...but i still cant get it to work i
have also tried virtual dub for frame serving but i get some error as it
wont work ...anybody have any suggestions??![]()
Results 1 to 9 of 9
go here http://entiendo.gotnet.net and look at the dvd makin section which shows how to set up dvd2avi after ripping a movie.
thanks ... i'll take a look at it ...anyways does anybody ever had the same problem??
Are you certain that your audio is set to "decode" the dolby in DVD2AVI? If this is not set to decode then no WAV file is generated.
Even a broken clock is right twice a day. -
yes ... under audio and output method i have checked to decode to wav
(AC3, LPCM) and i have checked dolby digital decode - dolby surround
downmix ...anything else that could be wrong??
Have you saved your project? This should create the .wav and the .d2v as well!
Have you selected a track number under audio? If so, try "auto select" under "audio-->channel format."
Frameserving From VirtualDub to MainConcept
By hech54 in forum Video ConversionReplies: 0Last Post: 8th Mar 2012, 09:24 -
frameserving dvd to premiere to avoid demuxing, is it possible?
By codemaster in forum EditingReplies: 3Last Post: 7th Jan 2011, 15:11 -
frameserving, from premiere to autogk
By codemaster in forum EditingReplies: 0Last Post: 26th Dec 2010, 19:57 -
FrameServing from Vegas 9 to MeGUI
By Kit-10 in forum Newbie / General discussionsReplies: 8Last Post: 4th Dec 2009, 17:12 -
Frameserving Options?
By echo1434 in forum ProgrammingReplies: 0Last Post: 9th Sep 2007, 21:31
