  1. I have ripped coded and burned the film of my wedding to a dvd+r, with no problems. But I am unsure as to how to duplicate the dvd with so i can delete the files off the Hard Drive.
    I Have burned the files in nreo using the DVD Video wizard(audio_ts and Video_ts) folders.
    Any Help Appriciated..
    Rich
  2. either I forgot how to read english or just don't know what the hell you are saying..but I'll give it a shot. Are you saying that you burned your wedding onto a DVD+R and want to make "additional" copies, but BEFORE doing so, you don't want to delete anything off your HD because you may lose it?
    If that is what you are asking..then all you have to do is have a DVD ROM and DVD BURNER on the same computer..just put the blank disk in the burner..and the DVD+R in the DVD ROM..and make an exact copy. Very simple..IF that is what you are asking.
  3. You don't even need to have two seperate drives.
    Simply load up NERO and start up the wizard & click on COPY DVD.
    You'll be instructed to put the original DVD into your drive, NERO will then copy the files into temporary memory. When done, NERO will instruct you to put a blank DVD+R into the drive and it will automatically burn.
    For the future, all you need to do is keep a copied disc for yourself and you can do this as often as you want.
    The only worry is that your disc may get damaged in the future, but this is a small risk.
    If you are really worried, then keep two copies on DVD+R. Or buy yourself a big fat 200GB hard drive!
    Hope this helps.
