Results 1 to 12 of 12
  1. The Mustang King arcorob's Avatar
    Dec 2001
    Seattle
    I never had problems with the trial.
    Now, with the Offical copy and first patch, every movie has stops, blocky pictures that appear, etc.
    Tried taking the PDI's and converting with PDI2ISO , same spots, same problem.
    With the trial, It worked in all machines. With the official, vesion, some wont even work in my apex and work with errors in my PIONEER.
    Maybe uninstall and go back to original without patch ?
    HELP
  2. I have the full version and never patched which seems to work good however I don't use the program any more since DVD95 Copy is so much faster and does the same thing.
    http://www.dvd95copy.com
  3. The Mustang King arcorob's Avatar
    Dec 2001
    Seattle
    question..I have DVD95 COpy (older 1.1 ) version...Dont remember being able to omit items...It may be faster but isnt it a bit buggy ? Hmm...
    Have to retry....
  4. Originally Posted by arcorob
    Have to retry....
    The new version 1.3 (I think) lets you omit whatever you want and is very flexable and of course fast. Most movies takes 70 to 90 minutes for me on my P4-2.53GHz system. The demo they have up is an older version so be aware of that.
  5. The Mustang King arcorob's Avatar
    Dec 2001
    Seattle
    I dont see a way to upgrade to 1.3 though..They mention updates but dont have any...hmm...Makes me wonder how official my copy is..I honestly didnt remember I had it till you reminded me...
  6. Originally Posted by arcorob
    You have to email them and then they will mail you back with a link to download. I just did that two days ago and got an answer back in a few hours.
  7. Hi,
    I have the same problem please let me know if you find out what is wrong.
    The movie freezes for little moments and there are those blocky picture things popping up once a while. It's killing me I don't know what it is I have tried everthing but can't seem to solve it.
    CYA,
    Ray
  8. The Mustang King arcorob's Avatar
    Dec 2001
    Seattle
    Are you running the basic install or did you add the first patch ?
    I just removed the whole thing and re-installed.
    By the way, those blockys and FREEZES dont happen on my Mintek...Go figure.
    The sad part is my APEX and PIONEER played EVERYTHING. Now I have an easier tool and it makes life a challenge.....
    Will let you know...
  9. I have this serial number I enter and I have used that from the beginning. The version I'm using is DVD2one111.
    I'm now trying it with a different proccesor and motherboard wich is also an AMD. I want to C if the problem is gone if so I know for sure it's no problem with my HD or XP.
    Jul 2001
    arcorob, dvdgek,
    The problems your describing, blocking - freezing, actually sound like media issues.... Have you recently changed to a different brand of disk?
    If the movie plays fine like a software player like WinDVD or PowerDVD or whatever, its probably not InstantCopy that is at issue but the media or burn process you're using.
    Have a good one,
    neomaine
    NEW! VideoHelp.com F@H team 166011!
    http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
    Folding@Home FAQ and download: http://folding.stanford.edu/
  11. HI,
    No it's not the media the files are corrupted after the decoding and I can check this with windvd. I have changed my Motherbaord and processor and now the problem is gone
    I still haven't figuered out what is causing it.
    Thanks for the advice,
    DVDGEK
  12. The Mustang King arcorob's Avatar
    Dec 2001
    Seattle
    I would agree however -
    Media is the same box, same supplier - RITEK Purple bottoms
    The same movie ripped and burned with other tools work perfectly
    My Mintek reads them but then again, the Mintek would read a Pizza if you put it in
    Somehow, I think it is the first patch.
    I have uninstalled and reinstalled...Will try again because In the beginning..There was nary an issue...LOL
    I am also playing with DVD2DVDR and DVD95 copy as well as some others...The sick part is I PAID for Pinnacle as the final choice....Uggg
