Everytime i open Smartripper, a message pops up and said..no ASPI-adapter available.
what's does that mean?
Results 1 to 30 of 40
Download and run this freeware utility called "ForceASPI" and that should fix the problem.
http://www.afterdawn.com/software/cdr_software/cdr_tools/frcaspi.cfm -
It means you need an ASPI layer. It's how your drives communicate and exchange information. In this case, it's how it exchanges information with Smartripper. At least, that is how I understand it.
What you need to do is look for and download ForceAspi. Make sure you get version 4.60 (1021). It claims it's for Windows versions earlier than XP, but it works just fine on XP (if you are using XP). After you do the install, make sure you reboot. Then, you can do an aspi check and it will probably say everything is functioning just fine.
This site may have what you are looking for. Hope this helps! -
The link I gave you is for version 4.6 of the Adaptec ASPI.Originally Posted by Beautiful Alone
where did you get 2.6 from these posts?
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
Okay, i've just downloaded the file, but i can't seem to find the setup file.Originally Posted by Bob W
Just double click on the file and it should put an icon on your desktop so open that and follow the on-screen directions.
Here is a direct link to download ForceASPI http://www.afterdawn.com/software/cdr_software/cdr_tools/frcaspi.cfm#download . The file is a zipped file about 150KB in size so you need to unzip the file using winzip. When you have unzipped the file it will be an ".exe file so just open the file or program.
Hi everyone... funny post
Download Force ASPI v1.7 using THIS link :
http://www.afterdawn.com/software/dawnload.cfm?mirror=322&software_id=409
Then click on the word "Download" in the middle of the page. This should open another page and start downloading after a few seconds.
Hope this helps.
Greetz,
pSYChO dAd
p.s. If you still can't figure this out, i'll mail you the Force Aspi kay!The difference between genius and insanity is only measured by success ! -
an older version won't help you.
What is the latest verison of SmartRipper? and whats Smartrippers offical website? I'm currently using Smartripper 2.41
that's the one i use. you need to install the aspi layer.
that is the latest. i don't think it has a site.
look at the rest of this thread. Bob W, jester1x, and Psycho_Dad_Rules have already told you how.
1: Download "Force ASPI".
2: Unzip the file you just downloaded.
3: Locate the folder you just unzipped to and there is a file there ending with ".exe" double click on it.
4: Follow the three step on-screen directions.
Wrong m2v file length with SmartRipper
By kenj in forum DVD RippingReplies: 9Last Post: 11th Jul 2010, 18:44 -
AutoGK, DVDShrink, SmartRipper won't recognize stream language/info
By takearushfan in forum AudioReplies: 5Last Post: 26th Sep 2009, 20:21 -
SmartRipper -- question about "Search Intensity" setting
By Dr.Rock in forum DVD RippingReplies: 1Last Post: 30th Dec 2008, 14:26
