I get this Error:
Can't Decompress frame 0
when I try to make a SVCD with DVD2SVCD.. and TMPGenc says the same...
What's the problem... and how do I solve it??
Please Help Me
Diddan
Results 1 to 10 of 10
Sounds like the AVI header is corrupt to me
Make a copy of the file, and use DivFix on it (I hate it, but it might work for you)
If not, 4CC might workThx in Advance!! -
posting this question just once is a good thing -- posting it three times is a bad thing .. thanks ..
Maybe you don't have the proper codec needed to decompress the film. Use gspot which is available in the tools section of this web site. It will analyze the film and tell you what codecs are needed and if you have them installed in your system.
I Have analyzed the movie with G-Spot... It says that all codecs are installed...
What can I doo to fix the frames?? -
Try using V-Dub MP3 Freeze. It will inspect your video and give you a list of bad frames. You can then delete them using virtual dub. You can get the MP3 Freeze version from the download section of
www.digital-digest.com. -
I Got that program... Its says that ALL frames are bad... but i have seen the movie in AVI format... it's fine....
I don't understand
