    Portland OR/Hita Japan
    I have everything ready for my svdvd thing.
    The problem is, i would like to add subtitles in, but dvdsp wont accept:
    .spc
    .srt
    .sub
    Please help
    Q
    "Good Luck 007"
    In Memory of Desmond Llewelyn
  2. You can export .sub thanks to TitleLab (alpha) is freeware which will convert yr subs in a .txt file. Then use Subtitle editor provided with DVD SP.
    KEEP FAITH
    Thank you soo much
    I have finally figured a way to get the subs off a dvd to .sub format using mencoder.
    Thanx
    Q
    "Good Luck 007"
  4. How did you do that. I'm interested.
    KEEP FAITH
    ok
    ive done it once, and its a bitch to wait for.
    ok
    insert your dvd
    then open a new terminal and type
    mplayer -dvd 1 -sub 1 -dumpsrtsub -sid 1
    the -sub indicates what subtitle to rip, the -sid indicates the same.
    try this
    ull have to wait since it has to actually play the whole movie.
    Q
    "Good Luck 007"
  6. great. giving it a try. I need .sub coz DVD SP can't read .spc file which comes with when ripping with Osex. tks
    KEEP FAITH
    Hrmmm
    Ive tried maybe 70 different ways in the past 24 hrs. Ive got one of them done, but it uses mencoder, and u have to do a whole encode to get the subs.
    I PM'ed major and asked him about adding it to ffmpegX. Im still waiting for him to respond.
    Hopefully, he will find a way of adding it in, then are sub problems will be over(maybe).
    Q
    "Good Luck 007"
