How do you get tempenc to convert an avi file into mpg when its encoded with XVID, i have the xvid codec installed and can watch the files perfectly but when i try to convert the file the audio is present but the video is a black screen.
Any help anyone can give is most appreciated.
If you strangle a smurf what colour does its face turn
Did you adjust the Direct Show priority like the TMPGEnc Common Problems guide said to?
Hello. -
An easier way I have found than changing the VSAPI settings in TMPGenc is by using Nic's FourCC changer which comes with the XVid codec install.
Drop the xvid into the 4CC changer, change it to a divx, then convert no sweat.
TMPGEnc 4.0 XPress XVID Compression Confusion & Archival Suggested Setting
By timmer545 in forum Video ConversionReplies: 4Last Post: 26th Mar 2011, 11:54 -
AVI (xvid) into TMPGenc plus HELP
By efiste2 in forum Video ConversionReplies: 3Last Post: 4th Dec 2010, 18:30 -
XVID/mp3 file wont open in TMPGENc express
By efiste2 in forum Video ConversionReplies: 5Last Post: 14th Jan 2010, 17:16 -
Help converting a Xvid to DVD with TMPGEnc 4.0 XPress
By ozzhead42 in forum Newbie / General discussionsReplies: 1Last Post: 19th Dec 2007, 15:01 -
xvid files act weird in TMPGENC
By briansmccabe in forum Video ConversionReplies: 4Last Post: 11th May 2007, 23:53
