Hello there,
I'm hoping someone that uses DVD2SVCD can give me an advise how to "lower" the permanent subtitles. As you can see on image below - this is how all my ripps look. I would be very happy if anyone out there could tell me how to get, if not all but much of the subtitles further down.
I "always" chose to add borders to my ripps - still I don't seem to get it right![]()
I've also tried to change the STD. Y-pos and EXT. Y-pos - but it just won't work. Please if anyone knows - tell me.
Regards
EvIL
:eplus2: <|>The Time Flies When You're In A Coma<|>
Comrades, almost 60 views and no reply/help.
Darn, I thought someone could help me with this matter,
I guess no else has it!? Or maybe I havn't explained it well??
EvIL:eplus2: <|>The Time Flies When You're In A Coma<|> -
OK I actually have a question for, you are adding permanent Subtitles right ? and are you making a Standard SVCD or an XSVCD...?
Check out my guide on converting .OGM format to an SVCD with Selectable Subtitles and Multiple Audio tracks.
https://www.videohelp.com/forum/userguides/170944.php -
Hello DivXerouS,
I am making (standard) SVCD's.
Since I'm a Swede I mostly/normally make PAL SVCD's with
Swedish subs.
I have never made any XSVCD's, is it easier making XSVCD's
with subs??
I'm very satisfied with the outcome of my SVCD's (DVD-backups),
except from the subs.
Unfortunately no one seems to be able to help me
Thanks:eplus2: <|>The Time Flies When You're In A Coma<|> -
The thing is XSVCD's are Non Standard (the X stands for Xtended BTW I had to find that on my own) XSVCD's, have a very high bitrate and can enhance the movie further more, but your DVD player has to support it. For the Audio I usually don't downsample it to 41,00HZ but leave it at 48,00.HZ cuz it plays perfect on my DvDPlayer. I usually squeeze the Video in a little bit more by lowering the Audio to 192. I prefer XSVCD's due to that fact they come out really good and have very little Macroblocks. Very little.
Now the thing is that I have not found anything on the net or any post that explains about XSVCD's with subtitles but I found an interesting link that says thathere is the link:-it is impossible to have Subtitles & multiple Audio tracks with XSVCD's
http://www.matco-video.com/DL/6XX/VCD_DVD.PDF
I have no confirmation if that is true or not because noone has said anything about it, and according to the guides available they usually require you using I-Author to Mux the subtitles and Audio (BTW I-Author is not available anymore), this is the information I have found so far. If you have any other questions please ask I will try to help you the best way I can...
One more suggestion came to mind. Since your making Standard SVCD's, maybe you should try making SVCD Selectable Subtitles. Are you making Permament or Switchable subtitles....?
If you don't understand what I'm saying try this link as well. Very helpful.
https://www.videohelp.com/xvcd.htmCheck out my guide on converting .OGM format to an SVCD with Selectable Subtitles and Multiple Audio tracks.
ffmpegX burned subtitles are missing with arabic (iso-8859-6) subtitles
By eswenson in forum ffmpegX general discussionReplies: 6Last Post: 11th Jan 2012, 08:22 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 17:30 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 09:23 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 16:28 -
Help with converting DVB subtitles to idx/vob subtitles
By Talayero in forum SubtitleReplies: 8Last Post: 21st Feb 2009, 17:10
