I want to make Vcd so i need to turn my Avi into mpeg.
There is a few things i dont understand.
Im using TMPGEnc to turn avi into mpeg, but for some reason sometimes it wont encode sound.why??
So i tried to use another prog to encode the sound separatly(i used avi2wav).
So far it seems it worked good.but i dont understand why TMPGenc cant encode sound sometimes.
I got this other movie i tried to encode...all worked good,but the encoding time is just sooo slow!
the movie is in 2 part.CD 2 took me 3 hours to encode(thats normal speed for my comp i think).Then after that i encoded CD1 and it took me 22 hours!!.I dont get it.
Not to mention that after turning those 2 AVI files into mpeg,my nero wouldnt burn them into VCD directly...he had to encode it again(2 hours encode for each CD)
Also i got this other avi movie which i didnt have to turn into mpeg to make a vcd.The file is clearly an AVI and all i had to do was using Nero to make vcd,no encoding needed,thats wierd.
so can someone help me?and maybe tell me if the encidong speed is normal for my comp?
i have :
Win XP
756 rams(pc133)
AMD 950
thank you
Have you tried using virtualdub with frameserve? I had this problem awhile back and this seemed to work for me.
First of all I think you really need to read up on some of the guides and info all over this site, but I will try to answer a few of your questions.
Hope this helps,
Read around the subject and try a few of the guides and you will soon learn how to overcome most of the problems you encounter.
Problems with turning image sequences into movie files for timelapse?
By adam-tl in forum MacReplies: 26Last Post: 2nd Dec 2011, 06:05 -
turning multiple avi files to dvd
By videodude1966 in forum Video ConversionReplies: 1Last Post: 23rd Dec 2010, 18:32 -
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 14:11 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
Problems with mpeg after conversion, or with original avi - help
By krisbee in forum LinuxReplies: 1Last Post: 30th Oct 2007, 16:56
