I have encountered a strange problem when authoring a dvd in ntsc format. The problem has something to do with
the framesize used in the mpeg2 file.
If i author the ntsc dvd with a mpeg2 file in 352x240 then it plays very jerky and skips randomly on my philips dvd711 player.
If it's authored with a mpeg2 file in 352x480 or 704x480 or 720x480 then it plays perfectly.
I do all my dvd authoring with spruceup, but i have also tried dvdit pe, same result. I have also encoded the 352x240 mpeg2 file in different bitrates, same result.
This problem is only on ntsc format, pal works perfectly on all framesizes. I'm living in a pal country so this problem is not that seriosly.
I have also tried with a mpeg1 file in 352x240 same problem. I hope someone has an answer why using a mpeg file within the dvd spec doesn't work.
Vcd4ever.
Results 1 to 1 of 1
Help! Cannot rip this DVD - wierd problem...
By Comfy in forum DVD RippingReplies: 2Last Post: 8th Dec 2009, 11:10 -
WIERD DVD data disk problem
By bruinflight in forum Newbie / General discussionsReplies: 24Last Post: 25th Sep 2009, 00:53 -
Wierd REWIND Problem... on standalones only!)
By taboo in forum DVD RippingReplies: 4Last Post: 16th Feb 2008, 22:29 -
Help! Wierd problem of Sharp Aquos 46D64U
By cryogenics in forum DVB / IPTVReplies: 3Last Post: 3rd Dec 2007, 23:56 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 12:34
