how to i make it so that when i watch a Full screen SVCD movie on my TV, it doesn't zoom it. i noticed it zoomed in when it showed the MiraMax logo, the M and the X was cut off)...but when i watch it on my computer, it perfect (how it should be...i used DVD2SVCD to make it (the original DVD was a Full screen)...so is there something i need to check/uncheck to make it so.
thanks for any help.
Results 1 to 12 of 12
this is called overscan not zoom.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
oops...my mistake
here's the revised one:
how to i make it so that when i watch a Full screen SVCD movie on my TV, it doesn't overscan. i noticed the overscan when it showed the MiraMax logo, the M and the X was cut off)...but when i watch it on my computer, it perfect (how it should be...i used DVD2SVCD to make it (the original DVD was a Full screen)...so is there something i need to check/uncheck to make it so.
thanks for any help.[/b] -
keep it up, newbie.
thanks for the name of it, i found other topics that talks about it, hopefully i can find the answer there.
was that so hard? you should search first instead of making another post and contributing to the hundreds we already have on this same exact question.
not trying to be mean or anything but if i knew it was called overscan then i would of done just that but i didn't...
Download the SVCD demo disk (this will show you the amount you need to cut off).
Next re-encode the image and cut a margin -
if the ovie was originally full screen (4:3 aspect ratio) all you should have to do is make sure you select that aspect ratio in dvd2svcd.
you should try using
There is a plugin for DVD2SVCD that will enable you to perform accurate cropping and resizing, and TV overscan optimized. you can save bitrate and also speed up encoding process.
its called
AutoFitCD v1.4
you can download it here
http://home.t-online.de/home/340044300675/autofitcd.zip -
with the autofit cd program you will also need
Fitcd v 1.1.2
which you can download here
http://shh.dvdboard.de/.
How to install
Simply run AutoFitCDSetup.exe and follow the instructions.
AutoFitCD requires FitCD. The plugin, Readme and source code
will be installed to a AutoFitCD subdirectory in your DVD2SVCD
installation folder. Note that this plugin supports both
AVISynth 2.0.x and 2.5.x but you need to reinstall it after
switching AVISynth versions.
Usage
Start DVD2SVCD, go to the Frameserver tab and select "AutoFitCD
Detect Borders" from the Avisynth Setup dropdown. Now go to the
Conversion tab, load the AVI/IFO/DVD and click "Go! - Preview
video". There will be lines indicating where AutoFitCD detected
black borders. Click "New Frame" until the motion area is
properly detected. If it is an overall very dark movie and the
motion area is not being well detected, lower the Borders
Threshold value at the bottom of the preview window (0-255,
default is 25).
Now click the "AutoFitCD >>" button in the preview window and
FitCD will be launched with all the correct settings (motion
area and borders detected during the preview, source and target
aspect ratio etc.). The preview window will automatically
update to reflect the optimized cropping and resizing
calculated by FitCD.
3d movie has spilt screen I want it full screen please help.
By stadelbauer in forum Newbie / General discussionsReplies: 9Last Post: 18th Dec 2013, 17:46 -
how can i removed crop with winff and make full screen
By phoenixa in forum Newbie / General discussionsReplies: 1Last Post: 16th Feb 2012, 03:48 -
how can i make full screen to my philips gogear vibe?
By phoenixa in forum Newbie / General discussionsReplies: 1Last Post: 15th Feb 2012, 11:01 -
Windows Media Player 8 full screen DVD playback not full screen
By brassplyer in forum Software PlayingReplies: 1Last Post: 3rd Jan 2012, 15:43 -
How can I convert a widescreen movie to full screen movie on PSP?
By VidHunter in forum MacReplies: 2Last Post: 9th Nov 2008, 22:20
