First, I use DVD2SVCD with TMPGEnc as the converter.
My first question is, the whole process takes about 10 - 12 hours in regular. But half the time TMPGEnc is analyzing the movie. Does anyone know how to take away this option??
Second, I'm not satisfied with the subtitles I get on my movies. Does anyone know how to do so that the subs always get below the movie so to speak. I mean below the movie itself and down in the black border /field below??
:eplus2: <|>The Time Flies When You're In A Coma<|>
The 'Analysing' is the first part of a Multi-pass VBR encode.
To eliminate it you need to change to a Manual VBR or Constant Bit Rate encode.
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 17:01 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 16:28 -
DVD2SVCD Vista compatibility
By Kibble in forum DVD RippingReplies: 5Last Post: 19th Mar 2008, 09:51 -
DVD2SVCD with CCESP 2.70 - CBR 6kbps? No way around?
By Colmino in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2008, 00:48 -
AVI,DivX,XviD to DVD with switchable subs using DVD2SVCD
By Baldrick in forum User guidesReplies: 18Last Post: 6th Jul 2007, 16:08
