  1. ...to use a "Batch Job" in Vrtual Dub to convert AVI audio files to wav files? I sometimes have about 15 to 20 AVI files to convert and rather than having to do individually, I would like to set a "Run Job" for multiples. Can it be done?
    Sep 2000
    Northern Virginia
    you can batch with virtualdub but WAV exporting cannot. check the latest version of vdub to be sure
    The batch processing list is a text file in the program directory called
    "virtualdub.jobs". Since it is a program-generated and -maintained file of
    commands, you'll have difficulty creating this file by hand. The most
    straightforward way to add entries to this file is to check the "defer
    processing" checkbox in the dialog for File > Save [extended/segmented]
    AVI. Some operations, such as WAV exporting, cannot be batched as of yet.
    -- Avery Lee </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    <font size=-1>[ This Message was edited by: hitechjunkie on 2001-09-12 16:40:11 ]</font>
  3. Thanks a million.
