If I convert my files:
Audio Sample Rate: 48 kHz
Bit Rate: 192 kbps
Coding Mode: Stereo
Layer: II
123 MB
and
Video Resolution: 544x480
Aspect Ratio: 4:3
Frame Rate: 29.97 fps
Bit Rate: 15,000,000 bps
1.07Gb
Files to Half D1, obviously (??) they'll look better, They don't look bad as VCD but the source looks better.
If I use the settings from DMF2 for 1/2 D1 (352 x 480 x 2400kps = 4 hours per dvd.
Will it be worth it $$, they are TV shows, The processing time will be longer.
Is there a better template for TmpGenc for 1/2 D1 ??
Should I roll my own, what bitrate etc...
Thanks in Advance
Roger Y
I would try the www.kvcd.net D1 templates. They really look good to me.
Hello.
Need Help With Deciding on Bitrates
By W1nks in forum Video ConversionReplies: 12Last Post: 6th Dec 2011, 11:17 -
WD TV reccomended bitrates
By SCDVD in forum Newbie / General discussionsReplies: 3Last Post: 2nd Nov 2009, 00:20 -
Different Clips w/Different Bitrates for DVD?
By Quamatek in forum Video ConversionReplies: 16Last Post: 21st Sep 2009, 07:27 -
I need some help understanding bitrates...
By pwhyles in forum Newbie / General discussionsReplies: 1Last Post: 7th Apr 2008, 14:54 -
MP3 Bitrates..
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 23rd Aug 2007, 22:50
