I've ripped some dvd's then converted them to DIVX using mpeg mediator. If I configure the codec to crank up the bitrate, the result is phenominal, but it also spans 2 or more cd's. What I want to know is, how to get near dvd quality to fit on one cd, and/or what programs I should be using to achive this?
I have a side question also. When I crank up the video bitrate, on playback, if I let it play, everything works fine, but if I fast forward the movie, the audio gets out of sync, (audio further ahead). Why?
Thanks.
700MB divx files are very close to dvd quality (according to my eyes). So you don't have to crank the bitrate. But if you're talking about SVCD, your best bet it using 2 CDs.
Bravoxena
How to significantly reduce size of an HD video with nearly same quality?
By oedipust in forum Newbie / General discussionsReplies: 47Last Post: 22nd Feb 2014, 20:54 -
File size (quality issue) transferring video
By subba in forum DVD & Blu-ray RecordersReplies: 2Last Post: 29th Oct 2009, 05:53 -
want to capture video from my wii with decent quality/size!
By Darkstraw in forum Capturing and VCRReplies: 3Last Post: 10th Aug 2008, 16:07 -
Video for web - Quality vs. Size
By Jeff_NJ in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 18th Nov 2007, 04:14 -
MPEG-2 video quality by file size?
By 3lutz3toe in forum MacReplies: 1Last Post: 27th Jun 2007, 18:17
